using a client script to ensure 2 fields match on a form
patricklatella
Hi all,
I'm creating a form for new hires, and on the form I want to have 2 fields where the user enters the new employee's ID #.   The intention of the 2nd field is to ensure that they enter the number correctly, much like when you have to repeat an email address or a password on banking stuff.
the 2 variables that need to match are:
emp_workday_id
emp_workday_id2
So the user first enters the value in the first field, and then needs to add the value again in the 2nd field (emp_workday_id2).   What need is, if the fields do match, then it triggers a GlideAjax to lookup the user record to populate some other fields on the form.   I have this part in place and working.
If the 2 fields do not match, I need it to stop and give an alert that the 2 fields do not match.     Should I be putting this all in one catalog client script?   I'm thinking yes, but please advise.
if (newValue == ''){
g_form.setValue('first_name','');//name of field on form you want to auto populate
g_form.setValue('last_name','');//name of field on form you want to auto populate
g_form.setValue('supervisor','');//name of field on form you want to auto populate
g_form.setValue('emp_location','');//name of field on form you want to auto populate
var ga = new GlideAjax('u_employee_details_lookup_Ajax');//name of script include
ga.addParam('sysparm_name', 'getEmployeeDetails');//name of function on script include
ga.addParam('sysparm_user', g_form.getValue('emp_workday_id2'));//name of field on form triggering call
ga.getXML(EmployeeDetailsLookup); // Always try to use asynchronous (getXML) calls rather than synchronous (getXMLWait)
// Callback function to process the response returned from the server
function EmployeeDetailsLookup(response) {
var answers = answer.split(',');
g_form.setValue('first_name',answers[0]);
g_form.setValue('last_name',answers[1]);
g_form.setValue('supervisor',answers[2]);
g_form.setValue('emp_location',answers[3]);
now for the part that ensure the 2 fields I match I need help folding in something like this?
var ID1
var ID2
ID1=g_form.getValue(emp_workday_id);
ID2='current.emp_workday_id2';
//then something like
if   ID1=ID2//then it goes on to the GlideAjax line in my script above
else sMessage = 'Your entry does not match, please check the Workday ID number and re-enter.'; //and stop them from moving forward
am I headed in the right direction?
in this script showFieldMsg() syntax is wrong, please change it something like, and it should display the messge.
  g_form.showFieldMsg('emp_workday_id2' ,'Your entry does not match, please check the Workday ID # and re-enter');
Also, in earlier provided client script if condition has to be correct.
if (newValue == g_form.getValue('emp_workday_id')) field name is not in quotes
please check if this helps.
29 REPLIES 29
Sorry Its My bad, Ignore my last reply. AS ID1 & ID2 totally new ID it doesn't exist in user table. Just implement one of the two script I provided above. Those will work
patricklatella
thanks Arindam!   how does that fit into my script? i.e. where do I put that?
patricklatella
this is not quite correct, but close?
if (newValue == g_form.getValue(emp_workday_id));{ //so if this is true I want it to move on to the GlideAjax
else alert('Your entry does not match, please check the Workday ID number and re-enter.');
g_form.clearValue('ID2', '');
patricklatella
you are correct with the scenarios, see my added notes for what should happen in each:
Scenario-1: ID1 matches ID2 and ID1/ID2 exist in user table THEN IT MOVES ON TO POPULATE THE FIELD USING MY CLIENT SCRIPT, WHICH I'VE NOW MADE onChange BASED ON ID2...if the 2 match and there's a user record with a match, then it populates the fields.
Scenario-2: ID1 does not matches ID2 and ID1 exist in user table HERE IT SHOULD STOP THEM WITH THE ALERT TO CHECK THEIR ENTRIES
Scenario-3: ID1 matches ID2 and ID1/ID2 does not exist in user table. HERE I AM GOING TO WANT IT TO SOMEHOW AUTOMATICALLY CREATE A NEW USER RECORD.   AGAIN, THIS IS FOR A NEW HIRE, SO THEY HAVE A WORKDAY ID, BUT THEY MAY NOT YET HAVE A USER RECORD IN SERVICENOW, I WANT THE SYSTEM TO CREATE THE NEW USER RECORD IF THIS IS THE CASE.   This is the next thing I'll be looking to achieve.
Scenario-4: ID1 does not matches ID2 and ID1 does not exist in user table.HERE IT SHOULD STOP THEM WITH THE ALERT TO CHECK THEIR ENTRIES
So again, I think it's fine to just have the function of looking up the values to populate the fields on the form triggered by ID2, but I want it to only do that if the entry for ID2 matches ID1.
Does this help?
patricklatella
can this be done with one catalog client script?
