Using the Array for a group of Radio Buttons
nannette
Mega Contributor
I have a UI Page with a group of Radio Buttons.   I can't seem to make the array work because I have a ui_form instead of a form.   I need to use the ui_form because I need to use the processing script area.   Any help you can share will be greatly appreciated.
<g:ui_form id="ivr_survey">
    <table id="survey" width="100%">
        <TR>
          <TD><SPAN class="normal"><B><h1>Agent Survey</h1></B></SPAN></TD></TR>
      <TR>
        <TD><SPAN class="normal"><B><h3>I had the tools and/or resources required to resolve the caller's issue to the caller's satisfaction</h3></B></SPAN></TD></TR>
      <TR>
            <input type="radio" id="score" name="score" value="1"> Strongly Disagree</input><BR></BR>
            <input type="radio" id="score" name="score" value="2"> Disagree </input><BR></BR>
            <input type="radio" id="score" name="score" value="3"> Netural</input><BR></BR>
            <input type="radio" id="score" name="score" value="4"> Agree</input><BR></BR>
            <input type="radio" id="score" name="score" value="5"> Strongly Agree</input>
        </SPAN></TD>
      </TR>
            <td colspan="2" align="Left">
                    <button type="submit" id="submit" onclick="submitChanges();">Submit</button>
            </td>
Client Script
function submitChanges(){
var tlscore;
var scores = document.ivr_survey.score;
// var radios = scores.elements.score;
      for (var i = 0, len=scores.length; i< len; i++) {
            if (scores[i].checked ) { // radio checked?
                      tlscore = scores[i].value; // if so, hold its value in tlscore
                    break; // and break out of for loop
bernyalvarado
Here goes the latest. Compatible with IE
        <TR>
      <TR>
      <TR>
            <input type="radio" id="score1" name="score" value="1"> Strongly Disagree</input><BR></BR>
            <input type="radio" id="score2" name="score" value="2"> Disagree </input><BR></BR>
            <input type="radio" id="score3" name="score" value="3"> Netural</input><BR></BR>
            <input type="radio" id="score4" name="score" value="4"> Agree</input><BR></BR>
            <input type="radio" id="score5" name="score" value="5"> Strongly Agree</input>
        </SPAN></TD>
      </TR>
            </td>
  </table>
  </g:ui_form>
</j:jelly>
var scores = document.getElementsByName("score");
                      alert('Selected option value: ' + tlscore);
Berny
14 REPLIES 14
Sounds good! Please let me know if you have any questions.
Berny
I tried it on my personal instance and it works. Please give it a try.
Berny
Ohk. I didn't know that. Let me try this out on my instance. Is this documented somewhere @ w3schools?
Hi Aswin, you can find a reference here:
http://www.w3schools.com/jsref/tryit.asp?filename=tryjsref_radio_checked4
I hope this is helpful!
Berny
This didn't work for me the alert never shows.   I tried something simuliar but it never works.   The only way i have been successful is to just name each item differently for the Id and not use an array.
What version of Service Now are you working in.   I am using Eureka
