Compose Email stuck on loading for Problem,incidents records in Workspace
HimanshuS876326
Hi all,
I’m facing an issue in Customer Service Workspace where the Compose Email button is stuck on loading for Problem and Incidents records.
It does not open initially, but after a hard refresh, it starts working again and opens the new record compose email button, which is stuck on Loading.
This issue is only happening for the Problem, incident table — it works fine for Case and other tables.
Has anyone faced something similar?
Thanks.
9 REPLIES 9
Yes mate, try repair plugin once.
Ankur Bawiskar
@HimanshuS876326
Did you recently upgrade?
Raise a HI ticket with ServiceNow
Yes, we have a recent update with Now Assist—no other major upgrade.
almiramcwl112
Hello, have you found the issue to this? I am facing the same issue and can't find out what's causing it. Thank you.
Good Afternoon,
I just went through the same thing and the ITIL role was missing the email_composer role which gets added to the Related List 'Contains Roles'.
I hope it helps someone.
Kind Regards
Ashley
