How to display 3 variables in a single row in a Record Producer ?
07-29-2026 05:16 AM
Hi Experts,
I am working on a Record Producer in CSM and have a requirement to display three variables in a single row (3-column layout).
Currently, I have tried using:
- Container Start
- Split
- Container End
The available Split layout options are:
- 1 Column Wide
- 2 Columns Wide, Side by Side
- 2 Columns Wide, Alternating Sides
I also tried setting the Variable Width to 25% for all three variables, but they still render one below another instead of appearing in a single row.
My Record Producer is being used from a CSM/Portal page.
Questions:
- Is there an out-of-the-box way to display 3 variables in a single row in a Record Producer?
- Can this be achieved using Container Start/End and Split variables?
- If not, what is the recommended approach?
Any guidance or examples would be greatly appreciated.
Thanks!
07-29-2026 06:13 AM
Use mulitrow variable sets.
07-29-2026 06:25 AM
Hi @BokkalaS,
It's not a supported functionality in ServiceNow from OOTB. But still, you can proceed with MVRS variable sets.
