How to use FlowScriptAPI.getContextID() in script includes
Rajyalakshmi
Giga Guru
Tanushree Maiti
Hi  @Rajyalakshmi
What is your use case??
You can check  servicenow documentation : https://www.servicenow.com/docs/r/api-reference/server-api-reference/FlowScriptAPI.html
The FlowScriptAPI API provides a method to return the context ID of the running flow.
You cannot instantiate objects of this type. Objects of this type are created automatically and are accessible only in script steps and inline scripts.
FlowScriptAPI - getContextID()
Returns the context ID of the running flow.
ParametersName Type Description
None
ReturnsType Description
StringThe sys_id of the running flow.
This example assumes you have created a flow containing a Log action. This inline script generates the content of the Log message.
var contextId = FlowScriptAPI.getContextID();
return contextId;
