CSA risk expire solution help
Bola1
Hi Team,
Please, I just checked my CSA status and realized it is about to expire. I don't know how to fix it because it doesn't show or say I should take a delta test.
i look forward to reading from team members about solution
2 ACCEPTED SOLUTIONS
AshishKM
Hi @Bola1 ,
Please share the screen shot of that page.
Do you have CSA on your own expense or through employer's partner program.
Did you write last delta exam, if not then when did you get CSA cert first time.
-Thanks,
AshishKM
Mark Roethof
Hi there,
You extremely need to hurry up if your CSA is at risk... the delta's close next week! ServiceNow communicated very well on this. How did you miss this?
Anyway, just login to Now Learning, and search for the CSA delta, and the top result is:
Again, do hurry up. Only a handful of days left! So most likely you also need to pass in one go, no time for a re-take as takes another 24hours.
You could try to raise a Now Learning case for extension, though reading your reason, not much luck on that.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
There were no Utah deltas - remember, that's when the deltas changed from 6-monthly to annually.
Hi @Bola1 ,
In this situation I would suggest create a case ASAP.  Support person will definitely help you.
With thanks,
Suraj
Mark Roethof
Hi there,
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
