AI Agent Use Case not running in Now Assist Side Panel
03-31-2025 03:30 AM
I have created a use case and associated AI agents. When I open the Now Assist side panel, it doesn't show any output, but it displays results when tested.
04-01-2025 12:32 AM
Hello Paul,
Thanks for your reply!
I indeed had done the configuration in the same way, even I tried with setting up trigger conditions and assigned now_assist_panel_user role but still it was not functioning.
04-01-2025 06:32 AM
Hi @CA5 - is it ? if the same AI agent works in testing, against an incident, it should work on side panel as well. Point here you may missing is deploying in Use case. can you share the Use case configuration screenshot here?
secondly,. try on the same tickets from your now assist panel.
