ACL Issue
pallav_nagar
Hi Team,
I have created read ACLs with both admin and user roles for my Employee Enrollments custom table under scoped application Training Management on PDI. But, the when I try to test by impersonating one of the Users, the Create Enrollment module gives this blank screen below.
Could you please assist ?
Not for Read or Create. Only for Write I have a field level ACL.
As far as my understanding if the user is having the field level acl given role..
then as per acl behavior once you define any field level ACL on a table, the system stops falling back to table level write permissions for other fields. This means every single field needs its own explicit write ACL
still try debugging - refer this :
ACL debugging tools
Tanushree Maiti
Hi @pallav_nagar
  • If you are trying to restrict record at creating record -> Then instead of Read ACL , you need it to restrict by Create ACL
  • Check the Application Menus in ServiceNow Studio to ensure the Module itself is not restricted by permissions that block the impersonated user's navigation
  • Using security Analyzer/ Security debugger tool, check which ACL is conflicting
Sandeep Rajput
@pallav_nagar The best way to debug this issue is to use Access Analyser and analyse the permissions of the user who is facing this issue.
