Flow designer reference field value not coming in domain separated environment
shubhamdubey
Hi Team,
Good day !!
I am working in domain separated environment. when i submit the request that time reference field value is not coming but the same RITM i tested through flow expected value  i am getting .
I am not sure why the value is not coming when submit the request from native view
Any help would be appreciated.
Shubham
After submit the request from native view.pngTesting the same RITM in flow Test.png
16 REPLIES 16
@shubhamdubey
issue with domain restriction etc
check this
Catalog tasks are not created for RITMs - Domain Separation
Hi @Ankur Bawiskar already we have given the visibility to that user .
even though this things is working fine in workflow but not working in Flow designer.
@shubhamdubey
it's different when it comes to flow.
Hi @Ankur Bawiskar It is not issue with domain because i change the properties from "system user" to "user who initiated the session" then  it is working
AnushkaS
Were you able to find the solution for this, I am facing the same issue.
