Flow Designer Subflows
RacheleTashjian
I am attempting to build a subflow that will check the alm_entitlement_user table when a request for software that has a software model is submitted and prevent duplicate entitlements from being created.  I am not able to get it to work without hard coding text to look for in the entitlements table.
I'm trying to use Flow Designer, but if there's a better option, I'm open to that as well.
I wasn't sure which location to use since there's nothing for Flow Designer that I saw.
Any assistance would be appreciated.
I think i'm just having a hard time wrapping my head around the logic.  I'm also not sure how to handle the duplicates it finds, if it does find them.
@RacheleTashjian
you can use Lookup Record and then use IF flow logic to check if record was found or not.
What needs to be done for duplicates, you need to check with your customer
