How to put attachments on top in record producer
DevanshT
13 REPLIES 13
@DevanshT
Hope you are doing good.
prerna_sh
Hi @DevanshT
You can check for the OOB attachment, as suggested by @Ankur Bawiskar
If you don't want to use this, then simpler way is, just go to "Portal setting" in catalog
- Check "hide attachment", this will hide the OOB attachment. (which is visible in last of the record)
- Then Under related list, Click "New" in variables
- Add a new variable with "type attachment", and remember "a low number to position it at the top, like 50 or 100",
- After saving this, you will be able to see attachment at the top.
(Check Attached screenshots for your reference)
If my response solves your query, please marked helpful by selecting Accept as Solution and Helpful. Let me know if anything else is required.
Prerna
svirkar420
Hi @DevanshT , Tried this in PDI working as expected.
1. Create a new variable "Type- Attachment"  set the order of this so that this variable would appear at the top of the record producer this variable will allow you to upload the attachment same as OOTB attachment.
(Note- Check hide attachment field from catalog item's portal setting so that you won't be seeing two attachment fields.)
If this solution helps you please mark this solution as accepted and Helpful. As it will be helpful for future users and readers.
Best Regards,
Saurabh V.
@svirkar420 @prerna_sh
how would it allow uploading multiple files similar to how the OOTB paper-clip icon works?
Hi
@Ankur BawiskarI didn’t mention the ability to upload multiple files at once.
Also, @DevanshT didn’t specify that his requirement is to support multiple file uploads. The approach I suggested works for uploading a single file at a time. If the requirement is to handle multiple file uploads, then the OOB functionality should be used.
Prerna
