In requested for variables I need users of manger(manger is current login user)
Siva82
Hi Team,
I have a variable that needs to reference data from the user table.
In this case, I need to implement a reference qualifier. If the currently logged-in user is a manager, the variable should populate with the users managed by that person. Additionally, the variable should include the users managed by the logged-in manager's direct reports (ex:manger(3users)>> manger of manger(4users) = 7 Usrs need to populate)
For example:
  • If a manager (X) has 3 direct reports, the variable should return 3 users.
  • If another manager (Y) has 3 direct reports, and one of those users has a manager (Z) who oversees 4 users, the variable should return a total of 7 users (3 users from Y + 4 users from Z).
Thank you in advance
Sivananda reddy
@Siva82
use this and pass the logged in user sysId
var UserUtils = Class.create();
UserUtils.prototype = {
    initialize: function() {},
    getAllReportees: function(managerSysId) {
        var allReports = [];
        // Start collecting from the given manager
        this.collectReports(managerSysId, allReports);
        return allReports.toString();
    // Recursive function to collect reports
    collectReports: function(managerId, allReports) {
        var directReports = this.getDirectReports(managerId);
        while (directReports.next()) {
            allReports.push(directReports.sys_id.toString());
            this.collectReports(directReports.sys_id, allReports); // Recursively collect indirect reports
    // Function to get direct reports
    getDirectReports: function(managerId) {
        gr.addQuery('manager', managerId);
        return gr;
    type: 'UserUtils'
use this in ref qualifier
javascript: 'sys_idIN' + new UserUtils().getAllReportees(gs.getUserID());
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
12 REPLIES 12
Ankur Bawiskar
@Siva82
you should have advanced ref qualifier on that variable and bring in the users
what script did you start with?
Hi @Ankur Bawiskar
Thank you for your response,
I have user below scrpit inulde and advanced ref qualifier, But no luck
Script inculde
var UserFilterForCatalogItem = Class.create();
UserFilterForCatalogItem.prototype = {
    getFilteredUsers: function() {
        var currentUserId = gs.getUserID(); // Get the currently logged-in user
        var userGr = new GlideRecord('sys_user');
        // userGr.addActiveQuery(); // Only active users
        userGr.addQuery('manager', currentUserId); // Users whose manager is the current user
        var users = [];
        userGr.query();
        while (userGr.next()) {
// users.push(userGr.name.toString());
                var userman = new GlideRecord('sys_user');
                userman.addQuery('manager', users);
users.push(userman.name.toString()+userGr.name.toString());
        return users.join(',');
    type: 'UserFilterForCatalogItem'
javascript: 'sys_idIN' + UserFilterForCatalogItem.getFilteredUsers();
Thank you
Siva
Hi @Uncle Rob
Script inculde
        var users = [];
        userGr.query();
Thank you
Siva
@Siva82
check the script I shared below
Oh, ok... I get it now.  You want a reference qualifier to select only those users.
So when troubleshooting scripts its important that you do at least some logging.
Have you verified that the script is firing AT ALL?
Have you verified the value of the string field at any point in the first or second loops?
I'd start there.
