In requested for variables I need users of manger(manger is current login user)
Siva82
Hi Team,
I have a variable that needs to reference data from the user table.
In this case, I need to implement a reference qualifier. If the currently logged-in user is a manager, the variable should populate with the users managed by that person. Additionally, the variable should include the users managed by the logged-in manager's direct reports (ex:manger(3users)>> manger of manger(4users) = 7 Usrs need to populate)
For example:
  • If a manager (X) has 3 direct reports, the variable should return 3 users.
  • If another manager (Y) has 3 direct reports, and one of those users has a manager (Z) who oversees 4 users, the variable should return a total of 7 users (3 users from Y + 4 users from Z).
Thank you in advance
Sivananda reddy
@Siva82
use this and pass the logged in user sysId
var UserUtils = Class.create();
UserUtils.prototype = {
    initialize: function() {},
    getAllReportees: function(managerSysId) {
        var allReports = [];
        // Start collecting from the given manager
        this.collectReports(managerSysId, allReports);
        return allReports.toString();
    // Recursive function to collect reports
    collectReports: function(managerId, allReports) {
        var directReports = this.getDirectReports(managerId);
        while (directReports.next()) {
            allReports.push(directReports.sys_id.toString());
            this.collectReports(directReports.sys_id, allReports); // Recursively collect indirect reports
    // Function to get direct reports
    getDirectReports: function(managerId) {
        gr.addQuery('manager', managerId);
        return gr;
    type: 'UserUtils'
use this in ref qualifier
javascript: 'sys_idIN' + new UserUtils().getAllReportees(gs.getUserID());
✨ Certified Technical Architect  ||  ✨ 9x ServiceNow MVP  ||  ✨ ServiceNow Community Leader
12 REPLIES 12
@Siva82
        return gr;
    type: 'UserUtils'
Hi @Ankur Bawiskar
It works as expected. Thank you so much for help
Thank you
Siva
@Siva82
I believe the script I shared worked for you as per your comment earlier but seems you deleted that.
