Lookup Select Box - Reference Qualifier
StefanSrba
I am having dificulty understanding how to user Reference Qualifier on Lookup Select Box.
Things that I have searched for always asks to set Reference Qualifier to 'advanced' even thou that is option only for Reference type of field.
And now that I have an Reference Qualifier that has to be 'advance' I would like to know how to write the RQ itself.
This was created based on other question that people helped me with
javascript:
'u_detailed_descriptionLIKE'+current.variables.application_description+
'^u_operating_system='+current.variables.u_operating_system+
'^NQu_operating_system='+current.variables.u_operating_system+
'^u_category='+current.variables.category+
'^u_sub_category='+current.variables.subcategory;
But I would like to have better control on this, to trigger one part of RQ
only if application_description has some text in it and if not to go the other route.
Is this even possible with RQ or is this something that should be done with Catalog Client Script?
@StefanSrba
yes you can write normal javascript server side code.
ensure the query is set before you use query; as the last line in your script
@StefanSrba
Hope you are doing good.
HugoFirst
I do something similar in a List Colector on the server table.  I use the javascript tag to start things of with an IF... else clause:
Here's the RQ:
javascript:if (current.variables.application_instance == '' ) { "fqdnSTARTSWITHzzzz" } else {"install_status=1^u_application_instance=" + current.variables.application_instance};
