‎12-14-2020 01:25 AM
Hey Everyone ,
I want your help regarding the changed fields which appear on update of any record in flow designer.
I have shared the screenshot. My query is how to use these changed fields. I mean exactly what is their purpose. In my case they are read only I am not able to select anything.
Any help would be appreciated.
‎12-29-2020 03:36 AM
Hi Shruti - Please read my explanation in the following thread:
https://community.servicenow.com/community?id=community_question&sys_id=0aa94af9db6594101cd8a345ca9619bc&anchor=answer_d0fd0fbedb15ac507d3e02d5ca9619d8
You cannot access the field names directly after your trigger, since Changed Fields is an array of objects. You have to parse through each item in the array and then add your logic. Note in my example on the other thread after the Trigger, the first Action is a For loop to work through each item in the Changed Fields array. It looks like you're missing that step in the screenshot you posted.
‎12-14-2020 02:34 AM
Please refer the link above.
I believe you cannot select value from the data pills
‎12-14-2020 03:08 AM
I have gone through that link but my problem is not solved with it. I am not able to select the value from anywhere except while doing testing.
It is showing as in shared screenshot. But I want to select the value from the flow when the value of field changes. On test screen how i would take the advantage?
‎12-14-2020 04:06 AM
I am having Orlando Patch 7
I am able to pick it from right hand side data pill and add in the Condition
‎12-14-2020 05:25 AM
I am doing it in Paris and not able to perform it.
‎12-14-2020 05:37 AM
Not much sure for Paris version.
Please raise HI ticket with ServiceNow.
