ā10-07-2025 02:01 AM
I have a requirement to add the comment in the flow designer. I 've a flow it triggers When a project is moved to Planning state and an approval gets requested, I want a Comment to be added as "Approve the project for the next process"
can some one give me an example to how to add the comments in the flow designer
ā10-07-2025 02:36 AM
I don't think you can add that using "Ask for Approval" flow action. I couldn't find any logic to add.
You can use Before insert business rule on sysapproval_approver and see approval is getting inserted for which table and set the comments
ā10-07-2025 04:12 AM
Hi @Trupti Krishnam,
both me and @Ankur Bawiskar just told you how š
Please share where did oyu get stuck
ā10-07-2025 04:15 AM
I already shared the working script.
Seems you forgot to check above.
ā10-07-2025 04:58 AM
@Ankur Bawiskar thanks for the soultion!
