Project Management - Copy an Entire Project
hazyitsm
Is there a way to copy (or make a template of) an ENTIRE project. By entire, I mean tasks, User Resources related list, resource assignments, allocations ... everything.
When I try "Save All as Template" and then apply that to a new Project, it doesn't include any of the related list info like User Resources, Planned Tasks, resource assignments, etc.
When I try "Copy Project", the Planned Tasks are copied to the new Project, but no other related list info gets copied. No User Resources or resource assignments.
Any ideas? Thanks!
tony_fugere
Mega Guru
You'll have to build a custom UI action for that.
Or you can modify the "copy_project" UI Page to query and copy the other related records you need. This is what's called from the Copy Project UI Action.
JohnJasinski
I had the same issue.
My workaround was to export to MS Project then create a new file copy then import back.
This should be a wish list improvement for a future release.
