Flow Designer / Integration Hub: escaped absolute path not valid
Michal Sadowski
I've built a Flow action to connect two ServiceNow instances and implement a GET request. I'm pretty sure I followed all the steps as required but I keep getting the following error: escaped absolute path not valid.
What am I missing or doing wrong here?
See action set-up and error in Execution Details below
Frederic Rumeau
Hi Michal,
I have the same problem with Flow designer and apparently it comes from a new Chronium version update.
Same problem with Chrome & Edge.
If you try on Safari or another browser, which are not run on chronium engine, Flow designer should work...
Try 🙂
Take care
Fred
Thanks Frederic. Will do and let you know how it went. Thanks for the tip.
Thank you Fred!  I was having this same problem and switching from Chrome to Firefox fixed it for me.
Eric Gilmore
Mega Expert
So did it work? I ask b/c I tried it with Firefox and received the same error message.
