How to use Choice field values ​​in a flow
bonsai
I want to extract the value of a record's choice field in a flow.
In a data pill I get the label value.
Is there a better way to do this?
@bonsai
not possible. It's a platform behavior and it will always give choice label and not choice value
Is there a way to make the output value the internal value of the option?
@bonsai
@bonsai
Hope you are doing good.
Sylwek
Give a try with use .getValue() in Script Editor. It worked in case of assigning value of 'Data type', Choice field on asmt_metric table 🙂
Asha Patil
Question: How to use Choice field values ​​in a flow
Answer: Storing a field value in a flow variable using 'Set Flow Variables' step gives you choice value instead of label.
