Script is working in background script but not working in Business Rule
What seems to be the reason why script is working in background script but  not working in Business Rule?
@Community Alums
how many records you want to insert sn_grc_issue? 1 or some other value?
try this
	var entity = new GlideRecord('sn_grc_profile');
	entity.query();
	while (entity.next()) {
		var issue = new GlideRecord('sn_grc_issue');
		issue.initialize();
		issue.classification = 3;
		issue.short_description = entity.name + ' has a control test failure';
		issue.insert();
})(current, previous);
13 REPLIES 13
Hi @Ankur Bawiskar
Yeah, I don't know the BR is not working. The classification is not auto-populating.
@Ankur Bawiskar
From the Engagement form, when 1 item in the Audit Task (sn_audit_control_test) was Closed Complete and the Control effectiveness is Ineffective, it will create a Control Test Issue (sn_grc_issue)
The only request is to auto-populate the 'Classification' field in the Control Test Issue form.
The configuration of the Name field is already in place. The classification only needs to be added to be auto-populated as well.
@Ankur Bawiskar @AshishKM @Danish Bhairag2
So I found an existing BR
Can you describe the business use case here.
This BR configured for update on sn_audit_control_test table but you are not using this table record in script.
Seems like you are trying to create an Issue record for each record update in table ( sn_audit_control_test) but this code is trying to create Issue record(s) for each entity record as there is no filter condition applied ( as below )
entity.query();
If you are actually trying to create multiple Issue records for each entity then change to order of GlideRecord table.
entity.query();
                           issue.initialize();
                           issue.insert();
 This is just code update but i don't think your business use case is like that.
 -Thanks
AshishKMishra
Please accept solution and mark helpful if it helps you.
