System settings and Developer settings are not available for an admin user
Raj Krishnasamy
I want to get the System Settings and then Developers tab to choose an application. But I am unable to find those settings and It would be great if someone can direct me to the correct article to enable the feature.
Jaspal Singh
Mega Patron
Strange.
Can you logout and try logging again once.
Hi @Jaspal Singh - Yes. I tried many different ways and had other admins try as well. No one is able to find way to get to System Settings options.
Sandeep Rajput
@Raj Krishnasamy The settings can be made available via Instance Tools Utility Menu. This can be enabled via the following.
  • How to enable the Instance Tools Admin Toolbar:
    • Using the filter navigator, type in sys_properties.list and hit enter. This will open up the System Properties table.
    • Make sure you’re in the Global scope, then click “New”
    • Fill in the form as follows and hit save:
      • Name: glide.ui.next_experience.instance_tools_disabled
      • Value: false
    • Refresh your browser and the instance tools menu should appear.
Source: https://www.servicenow.com/community/next-experience-articles/what-s-new-in-vancouver-for-next-exper...
Should be up for admins, by default.
