External webcam is required or not for CSA
Hemanthmale
Hello ,
Can anyone please confirm the camera requirements for the online proctored CSA exam ? Is an external camera required ? or an internal laptop camera is ok ?
This is what I have received confirmation from ServiceNow my learning guide.
for exams taken on the Pearson On VUE platform, an external webcam is NOT required—your laptop’s built-in camera is sufficient.
Please confirm whether I should buy the external camera or not to give the exam
Thanks!
3 ACCEPTED SOLUTIONS
glideFather
Hi @Hemanthmale,
the external camera is no longer required after the exams were switched to a new platform (Pearson VUE).
You however need the in-built camera of your laptop
✂-----Cutting-out-the---✦AI-noise✦---All-replies-written-and-vouched-for-by-GlideFather---
Dr Atul - LNG
Hi @Hemanthmale
I recently took an exam with Pearson and can confirm that an external camera is no longer required for the online proctored exam. Please feel free to proceed with booking your exam.
Aditya_hublikar
Hello @Hemanthmale ,
There is no need for an external camera for the CSA proctored exam, but they do require a proper camera setup for monitoring. I recommend not attending the exam from home — it’s better to choose an exam center. One of my colleagues initially attempted the exam at home, but due to a technical issue the exam got submitted automatically and could not be recovered. At an exam center, if any issue occurs, the support or exam center team can help resolve it quickly.
All the best for your CSA exam 😀
If this helps you then mark it as helpful and accept as solution.
Aditya
Aditya_hublikar
Aditya
its_SumitNow
Hi @Hemanthmale
Since November 18 2025 , ServiceNow Certification exams are conducted by Pearson Vue, They don't require an external webcam, If you are planning to appear online at home, then I would recommend you to sit at a very quite place, because if there is little bit noise in your room then exam gets on hold,
Best Option is test centre, Apart from this, I recently appeared for CSA and shared my experience, Check it here , It might help you
https://www.servicenow.com/community/community-central-forum/tips-for-passing-the-servicenow-csa-exa...
All the Best for your exam !
if my response helped kindly mark helpful & Accept as Solution 🙂
Warm Regards
Sumit
Technical Consultant
