What is the difference between current.getTableName() and current.sys_class_name in terms of operation
08-05-2014 11:10 PM
I have used both current.getTableName() and current.sys_class_name in an existing Business to perform a specific operation .I got the desired output
by using current.sys_class_name ,But that did not work for current.getTableName().Please share your valuable inputs(practical scenario) apart from the Wiki.
Thanks in Advance.
- 67,153 Views
01-20-2016 10:03 AM
Actually, the field "current.sys_class_name" should exist on any extended table or its children, not just Task tables. You will see it wherever objects are extended from a base class:
- Assets
- CMDB
- Credentials
- etc.
I believe it would be there for custom tables as well, if they are extended/extensible.
-Brian
01-20-2016 10:08 AM
It works for any inherited tables, see my previous post. In a nutshell, sys class name lets you query a parent table and get the name of the child name whereas gettablename only sees the table you are currently on.
01-20-2016 10:18 AM
Sorry, refresh-overlap. I had loaded the page before your reply and was reading... and THEN replied myself.
Didn't see your post till the refresh.
Thanks for the explanation though,
-Brian
05-31-2017 06:02 AM
Hi Pradeep,
How can i get the table name for a custom table. As you mentioned above we cannot use getTableName of sys_class_name for a custom table. Let me know if there is any alternative for this.
01-20-2016 09:53 AM
Not intending to start up an old thread but the difference in output between sys_class_name and getTableName() depends on whether you are calling it on a table that is in a table hierarchy (which task is, but applies to any, custom or OOB).
If you were to query the cmdb_ci table for and print getTableName and sys_class_name for all records, getTableName would return cmdb_ci because that is the table you queried, whereas sys_class_name would return the actual record's table name if it should happen to be a child table such as application, database, etc.
*** Script: table name:cmdb_ci ------ sys class name: cmdb_ci_server
*** Script: table name:cmdb_ci ------ sys class name: cmdb_ci_network_adapter
*** Script: table name:cmdb_ci ------ sys class name: u_fmr_cmdb_network_traffic_manager
*** Script: table name:cmdb_ci ------ sys class name: u_cmdb_ci_app_web_server
*** Script: table name:cmdb_ci ------ sys class name: u_cmdb_ci_phone_num
*** Script: table name:cmdb_ci ------ sys class name: cmdb_ci_computer
*** Script: table name:cmdb_ci ------ sys class name: u_fmr_patch_panels
