Help Text Placement for Zurich Hot Patch 4
AdrianR3
Issue: After Zurich Hot Patch 4, help text for form fields is displayed beside the question label instead of below the input field. This layout can confuse users and does not follow standard UI guidelines.
Impact: Misaligned help text reduces clarity
Expected Behavior: Help text should appear directly below the question or as a tooltip, not in a separate floating box beside the label.
AdrianR3
UPDATE:
This is documented issue, and a fix it coming in the Australia version.
See workaround.
16 REPLIES 16
Trevor Jerue1
Thanks for posting this. I have noticed the same behavior. The .help-text class does not seem to be nested properly. I opened a case with support, will report back with any info.
AdrianR3
UPDATE:
See workaround.
We have to wait until Australia???
They aren't planning on fixing it in Zurich in a future Patch or Hotfix???
We only promote to every other release (in the fall).
It says on their knowledge article it's fixed in Zurich patch 5.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB2700084
