Help Text Placement for Zurich Hot Patch 4
AdrianR3
Issue: After Zurich Hot Patch 4, help text for form fields is displayed beside the question label instead of below the input field. This layout can confuse users and does not follow standard UI guidelines.
Impact: Misaligned help text reduces clarity
Expected Behavior: Help text should appear directly below the question or as a tooltip, not in a separate floating box beside the label.
AdrianR3
UPDATE:
This is documented issue, and a fix it coming in the Australia version.
See workaround.
16 REPLIES 16
Trevor Jerue1
I was able to apply the new CSS and validated it now loads as expected. Thanks @AdrianR3 for posting the full details of the workaround.
Alex Chan
A KB article related to this issue has been published in the support portal. There's a step-by-step workaround included in the article.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB2700084
