How to make a dashboard as default for users?
04-23-2024 10:12 AM
Hello Community Members,
We have some dashboards with lot of reports which takes time to load and hence affecting user experience to some extent. As per the current configuration, 'user preference' stores the dashboard SysID user visited last and opens the same dashboard when user login again.
How can we make a dashboard default for users so that after login users will be redirected to the dashboard marked as default for them?
PS: Post upgrade from Tokyo to Vancouver, homepages are removed and PA dashboard is the default new homepage.
10-23-2024 11:59 PM
Hi @Sylvie Pacholcz ,
If you change the default dashboard to other at the Home, It will display last dashboard opened again change your dashboard based on your need.
However basically for the first time if users login they will displayed with default page which you have given in User Preferences.
Pradeep
10-24-2024 12:27 AM
So I cannot use the "Home" menu if I open other dashboards than the Dashboard I would like have by default.
10-24-2024 12:35 AM
You can open by changing manually again, but by default for first time it will display the default dashboard unless users change it manually.
