Access to records is not same when impersonated.
01-21-2024 10:25 PM
when one user (X) can see records in a table, but when another user (Y) impersonates X, the records are not visible and a security constraint error occurs, suggests that there may be specific access or permissions set for user X that are not being properly applied during the impersonation.
The table is not global but Security Incident Response application.
01-21-2024 11:02 PM
Ideally, the access should be same unless you have introduced some customization to prevent impersonations to see the records.
Go through the read acls for this table and identify.
If above looks fine, raise a HI ticket, as it is a standard feature, SN support should be able to assist you with this.
