After Business Rule is getting Executed before my flow is creating Task and closes the RITM
Debasis Pati
This is my After update BR on SC Task Table
if (current.request.state != '5') {
var ritmSysID = current.request_item.toString();
var grRitm = new GlideRecord('sc_req_item');
grRitm.query('sys_id', ritmSysID);
grRitm.query();
if (grRitm.next()) {
//Update RITM State
if (current.state == 2) { //Work in Progress
grRitm.state = 2;
grRitm.update();
} else if (current.state == 3 || current.state == 4) {
gs.sleep(10000);
if (grRitm.stage != 'waiting_for_approval') {
var sc_task = new GlideRecord('sc_task');
sc_task.addQuery('request_item', ritmSysID);
sc_task.addQuery('active', true);
sc_task.query();
if (!sc_task.next()) {
if (current.state == 3) { //Closed Complete
grRitm.state = 3;
} else if (current.state == 4) { //Closed Incomplete
grRitm.state = 4;
grRitm.update();
var reqSysID = grRitm.request.toString();
var grReq = new GlideRecord('sc_request');
grReq.query('sys_id', reqSysID);
grReq.query();
if (grReq.next()) {
if (grRitm.state == 3) { //Closed Complete
grReq.state = 3;
} else if (grRitm.state == 4) { //Closed Incomplete
grReq.state = 4;
grReq.update();
})(current, previous);
My flow is responsible for 2 Task and updating them for automating the state and stages we have created the above BR.
This works fine when i put a delay but as this is not recommended what can be done.
The issue is whenever my first task is gets closed this br runs before the flow creates the other task and RITM value is setting to close complete.
@Ankur Bawiskar any suggestions please?
@Debasis Pati
you are using wrong variable name
try this
        var ritmSysID = current.request_item + ''; // Stringify sys_id
        if (!grRitm.get(ritmSysID)) return;
        // WIP: Set immediately (safe)
            grRitm.state = 2;
            grRitm.update();
        // Closed states (3=Complete, 4=Incomplete): Check ALL tasks first
            // Count ACTIVE tasks for this RITM - FIXED VARIABLE NAME
            var task = new GlideRecord('sc_task');
            task.addQuery('request_item', ritmSysID);  // ← WAS ritmID, NOW ritmSysID
            task.query();
            var activeTaskCount = task.getRowCount();
            if (activeTaskCount > 0) {
                gs.info('Active tasks remain: ' + activeTaskCount + ' for RITM: ' + ritmSysID);
            // No active tasks - safe to close
            grRitm.state = (current.state == 3) ? 3 : 4;
            grRitm.update();
            // Cascade to REQ if needed
            var reqSysID = grRitm.request + '';
            if (grReq.get(reqSysID)) {
                grReq.state = grRitm.state;  // Use RITM state
                grReq.update();
VaishnaviK3009
Hi @Debasis Pati !!
This is a timing / race condition issue between your Flow and the After Update Business Rule on sc_task.
When the first task closes, the BR runs before the Flow has created the second task, so your query for active tasks returns none and the RITM is closed prematurely.
gs.sleep() only hides the issue and is not recommended.
Why this happens
  • Flow creates tasks asynchronously
  • After Update BR executes immediately on task closure
  • Second task does not yet exist when the BR runs
Recommended Fix (Best Practice)
Move the RITM/REQ state logic into the Flow, since the Flow owns task creation.
Flow pattern:
  1. Create all sc_tasks
  2. Wait until all related tasks are closed
  3. Update RITM state/stage
  4. Update REQ state
This avoids timing dependencies and is fully supported.
Alternative (If BR must be used)
Use a count-based check, not timing:
var ga = new GlideAggregate('sc_task');
ga.addQuery('request_item', current.request_item);
ga.addQuery('active', true);
ga.addAggregate('COUNT');
ga.query();
ga.next();
if (parseInt(ga.getAggregate('COUNT'), 10) === 0) {
    // Close RITM and REQ
This ensures the RITM is only closed when no active tasks exist, regardless of creation timing.
Mark this as Helpful if it clarifies the issue.
Accept the solution if this answers your question.
Vaishnavi
Associate Technical Consultant
Kamva
Giga Guru
Hi @Debasis Pati,
I wish to give you a helping hand, but I am not understanding the requirement properly. You are using custom made flow to create two catalog tasks from a RITM? Then you want the RITM to be closed once the tasks have been closed as well?
Please clarify a bit, I'll assist you, I need to understand the requirement
