Flow Designer Error: Wait for Condition error "Invalid condition provided for table change_request"
‎12-21-2025 11:58 PM
Record is found but still error shown.
The field where condition is used is also correct
Plus, important thing to note is this runs w/o error in some cases and returns error in some.
When rerun, the error is not shown again in most cases!
‎12-22-2025 01:50 AM
‎12-22-2025 01:11 AM
@Hussain Marakar , check if the field is u_tasks_completed is setting the value correctly.
Investigate the logic that is supposed to set u_tasks_completed to true to ensure it is functioning correctly and completing its task as expected.
Nayan
‎12-22-2025 01:17 AM
I believe the value correct, the runtime value is True, the logic making this true also excutes successfully
‎09-29-2026 12:52 AM
Hi Hussain,
Did you solve this problem? If so, could you let me know how you fixed it?
This happens in my PROD instance as well.
I ran the flow in my DEV instance, but the issue didn't occur there.
Thank you.
