Flow designer flow - how to wait until a specific record is created in a specific table
11-27-2025 02:46 AM
Flow designer flow - how to wait until a specific record is created in a specific table:
I am working on building a catalog flow- where I need to update VMI records using Obj ID. This record will be created via vcenter discovery . Catalog flow should look for the VMI based on teh Obj ID entered in the RITM and once found it should update the VMI with group and owner info.
If I give fixed wait till - like 24-48 hours - even if there is a matching record - flow will still wait. I want to exit when the match found.
11-27-2025 05:46 AM
My thoughts
- Add a "Do the following until" block.
- Inside, use "Look Up Records" on the target table with your condition i.e. Obj ID == Value from RITM
- Add a "Wait for a Duration" action (e.g., 5 minutes) to avoid rapid polling.
- The loop exits automatically when the record is found.
Do remember to use a counter variable to prevent infinite loops
Do the following until flow logic
Count Do-Until loop in Flow designer
11-27-2025 08:02 PM
Hope you are doing good.
02-17-2026 04:04 AM
Hi @chaithra10,
You can use the ' Wait for the Condition action in the flow design; refer to the below article:
If you find my answer useful, please mark it as Helpful and Correct 😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
