Help in Requirement
Prithvi Ramesh1
There is a catalog item with a variable that references the "ast_contract" table. Whenever a contract number is selected, it should be in numerical order. The following attributes have been used for the variable:
  • ref_auto_completer=AJAXTableCompleter
  • ref_ac_columns=contrct
  • ref_ac_order_by=vendor_contract
  • ref_ac_columns_search=true
Each time a value is selected, it should be unique. Additionally, after selecting a value, the latest value should be set as the default without needing to select it manually. How can this be achieved?
@Prithvi Ramesh1
it does allow but you want the contract to be auto populated in 2nd row based on value selected in 1st
check this link if you can detect the row addition and have some logic to get the next Contract and set it onload
MRVS detect when a row is removed or deleted
@Prithvi Ramesh1
Hope you are doing good.
