how to send notification when kb article is going to expire in 15 days and 1 month
01-27-2026 10:39 PM
Hi Team,
please suggest how to configure notification which should trigger 1 month and 15 days before expiry date(valid to)
notification should trigger to contributor, approver manger and owner
FYI OOTB we have one month notification but we are not using it
01-27-2026 11:41 PM
Hi @Ankur Bawiskar
the OOTB notification and scheduled job is only for one month and also we have different recipients
so please suggest how to configure in flow design
please explain step by step or else please suggest the conditions and steps so that i can develop in my flow
01-27-2026 11:49 PM
you can run daily flow at particular time and check whichever KB are expiring in 15 days.
Then use For Each to iterate those records and use "Send Email" flow action
I already shared something for you to get started
01-28-2026 07:24 PM
Hope you are doing good.
01-27-2026 11:00 PM
@vamshi2 You can make use Scheduled job by navigating to: System Definition - Scheduled Jobs - Scheduled Script Executions for daily running.
01-28-2026 12:22 AM
Hi @vamshi2 , i have implemented similar requirement
System Definition → Scheduled Script Executions → New
Run Daily
use this script
var gr = new GlideRecord('kb_knowledge');
gr.addNotNullQuery('valid_to');
while (gr.next()) {
var validTo = new GlideDateTime(gr.valid_to);
var today = new GlideDateTime();
var diff = validTo.getNumericValue() - today.getNumericValue();
var fifteenDays = 15 * 24 * 60 * 60 * 1000;
var oneMonth = 30 * 24 * 60 * 60 * 1000;
// 15 days before expiry
if (diff > 0 && diff <= fifteenDays && !gr.u_15_days_notified) {
gs.eventQueue('expiry.15.days', gr);
gr.u_15_days_notified = true;
gr.update();
// 1 month before expiry
else if (diff > fifteenDays && diff <= oneMonth && !gr.u_1_month_notified) {
gs.eventQueue('expiry.1.month', gr);
gr.u_1_month_notified = true;
gr.update();
then
Create 2 Events: name
expiry.15.days
expiry.30days
and now for (duplicate notification )
create 2 check boxes on table ( this is required to validate for that record notification sent)
- u_15_days_notified
- u_1_month_notified
and then create the notification which will trigger by the event
