Need to call system property in UI policy client script
Aswin Chandras1
I have UI policy script doing some function.
In that I am checking for particular order guide using sys_id.
I need to replace that sys id with system property.
I have written script include for the same but it is not working.
SI:
var GetOrderguide = Class.create();
GetOrderguide.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getProperty: function() {
        return gs.getProperty('name of property');
    type: 'GetOrderguide'
UI policy script:
var ga = new GlideAjax('x_mosti_ms_hardwar.GetOrderguide');
ga.addParam('sysparm_name', "getProperty");
ga.getXML(myCallBack);
function myCallBack(response) {
var prop = response.responseXML.documentElement.getAttribute('answer');
With the prop I need to call in the below condition
if(finalParam == 'sys_id')// calling order guide sysy_id here
    g_form.setMandatory('variable_name',false);
g_form.setVisible('variable_name',false);
9 REPLIES 9
Hi @Ankur Bawiskar
Please find the full code.
function onCondition() {
var url = decodeURIComponent(top.location.href); //Get the URL and decode it
var workspaceParams = url.split('sysparm_guide')[1]; //Split off the url on Extra params
var serviceportalParams=url.split('sys_id');
var wkspaceParams=url.split('sc_cat_item_guide/');
//alert(workspaceParams);
var params = workspaceParams;
var allParams='';
var ans='';
//The params are split on slashes '/'
if(workspaceParams!=null)
allParams = params.split('&');
//alert(allParams.length);
//Search for the parameter requested
for (var i = 0; i < allParams.length; i++) {
if (allParams[i] == sysparm_guide) {
    ans=allParams[0];
    return allParams[0];
if(serviceportalParams!=null)
allParams=serviceportalParams;
//alert(ans);
var finalParam='';
if(ans!=null)
finalParam=ans.replace('=','');
if(wkspaceParams!=null)
finalParam=wkspaceParams[1];
var ga = new GlideAjax('GetOrderguide');
ga.addParam('sysparm_name', "GetOrderguideSYSID");
ga.getXMLAnswer(function(answer){
if(answer != ''){
    alert(answer);
//alert(finalParam);
if(finalParam == answer)
//if(finalParam == 'sys_id')
g_form.setMandatory('ms_ham_financial_approver',false);
g_form.setMandatory('ms_unlock_approvers',false);
g_form.setVisible('ms_ham_financial_approver',false);
g_form.setVisible('ms_unlock_approvers',false);
@Aswin Chandras1
I won't suggest to use UI policy for this.
use onLoad client script since your script is too heavy
@Aswin Chandras1
try this
    var serviceportalParams = url.split('sys_id');
    var wkspaceParams = url.split('sc_cat_item_guide/');
    var allParams = '';
    var ans = '';
    if (workspaceParams != null) {
                ans = allParams[0];
    if (serviceportalParams != null) {
        allParams = serviceportalParams;
    //alert(ans);
    var finalParam = '';
    if (ans != null) {
        finalParam = ans.replace('=', '');
    if (wkspaceParams != null) {
        finalParam = wkspaceParams[1];
    ga.getXMLAnswer(function(answer) {
        if (finalParam == answer)
            g_form.setMandatory('variable_name', false);
            g_form.setVisible('variable_name', false);
            g_form.setMandatory('ms_ham_financial_approver', false);
            g_form.setMandatory('ms_unlock_approvers', false);
            g_form.setVisible('ms_ham_financial_approver', false);
            g_form.setVisible('ms_unlock_approvers', false);
@Aswin Chandras1
Hope you are doing good.
-O-
I would approach this a bit different.
I would create a reference variable with "Visible on Summaries" not-checked so it is not included in notifications and stuff, UI Policy to always hide it and with the default value so that a property is not even needed. If it is to be used in more than one place, you might make it a variable set and include as needed.
Now, because it is just a variable as any other, you can use it in UI Policy conditions and you don't need to write a single line of script.
Lite on the system, easy to maintain.
