Need to hide variable set on catalog item from a order guide
Aswin Chandras1
I have an order guide Replace Request where it contains Laptop as catalog item and it is called in multiple order guides.
My requirement is if my order guide is replace request then I need to hide the financial variable set in the laptop catalog item which is called in the order guide. My variable set is in catalog item not on order guide.
For other order guide, the variable set should be displayed. My variable set is in catalog item not on order guide.
nishantkhet
Hi @Aswin Chandras1
Instead you can create the variable set in the order guide (in your case replace request) and include the catalog item (Laptop) in order guide. The second order guide where you don't want to populate the financial variables, create the UI policy for the same on the order guide itself.
Please mark the answer correct or helpful.
