on change client script using a synch call
AnjaliY27945328
    if(isLoading||newValue==''){
var ci=g_form.getReference('u_configuration_item',getCIdetails);
function getCIdetails(ci) // ci is object
g_form.getValue('u_asset_tag',ci.Asset_Tag);
g_form.getValue('u_serial_number',ci.Serial_Number);
the script is not working on changing ci value
no auto populate value of asset tag and serial number
pls check and tell me where I am wrong
Rupanjani
Giga Guru
Hi @AnjaliY27945328 ,
Use setValue instead of getValue to set the values on the fields.
setValue - sets the value on the field.
getValue - retrieves the data from the fields.
Mark the response correct and helpful if the answer assisted your question.
