Order guide- add to cart button
robertpetrovics
Hi Guys!
I'm trying to set up an order guide accesible from the core UI from service catalog. However I'm not able to enable the add to cart button. I added the catalog items to the order guide( 3 step). When I get to the catalog items selection they kinda all go to the cart when I press procced to checkout and I don't have a add to cart option at each catalog item individualy. Can you give me a hand with this?
9 REPLIES 9
I'm not finding this script, it's a script include right?
Hello @robertpetrovics ,
Did you check the above article which I shared that is providing the OOB solution and you can adhere that.
yes, but that is not working.
This documentation will definitely help you.
Add a catalog item to the shopping cart (servicenow.com)
Please mark my solution as accepted and give thumbs up, if it helps you.
unfortunately it does not
