related Incident field in problem form link to related problem field in Incident form .
RohitKumar24
Need to create a reference field in problem form named as related incident  which will refer incident table and on selecting an incident number on that field. After saving the form in the related incident  in problem table, that selected incident will be shown in that particular problem once opened with field name as related incident and vice-versa. When related problem is selected in incident table it should be shown in that incident page once opened .
Please let me know how it can be achieved?
ayan_murshad
Hi @RohitKumar24 ,
It looks like your requirement is for a Bidirectional Relationship between the Incident and Problem tables in ServiceNow. This means that if an incident is related to a problem, that relationship should reflect both ways—whether linked from the incident side or the problem side.
Here's a summary and steps to implement this:
1. Create a Reference Field in the Problem Table
    • Name: u_related_incident (using u_ prefix to denote a custom field)
    • Label: "Related Incident"
2. Related Problem Reference Field is already exist in the Incident Table
3. Business Rule for Synchronizing the Relationship
You'll need to create a Business Rule to maintain the synchronization between the two tables. Here's an example:
3.1 Business Rule on Problem Table
  • Table: Problem
  • When to Run: before Insert/Update
  • Condition: u_related_incident is not empty.
  • Script:
         var relatedIncident = new GlideRecord('incident');
          if (relatedIncident.get(current.u_related_incident)) {
             relatedIncident.problem_id = current.sys_id;
             relatedIncident.update();
3.2 Business Rule on Incident Table
    • Table: Incident
    • Condition: problem_id is not empty.
    • Script:
    var relatedProblem = new GlideRecord('problem');
    if (relatedProblem.get(current.u_related_problem)) {
        // Set the related incident field on the Problem record
        relatedProblem.u_related_incident = current.sys_id;
        relatedProblem.update();
Ayan Murshad
ayan_murshad
Hi @RohitKumar24 ,
  • Table: Problem
  • Script:
    • Table: Incident
    • Script:
Ayan Murshad
Thanks Ayan, for the solution.
Runjay Patel
Hi @RohitKumar24 ,
It available OOB.
From incident form if you add problem from related list section then it will start reflecting in related list on problem form.
From Problem to Incident you can bring "Parent" field on form and select incident number then it will start reflecting on related list of incident form.
If you want that parent filed should only show the incident then you can do dictionary override.
Part 2. In this video i have talked about overview on ServiceNow platform/tool. How you can opt for personal dev instance (PDI)? how to login in ServiceNow instance and navigation to OOB modules. For document please visit: https://servicenowwithrunjay.com/ Follow Facebook page for latest update on
Thanks Runjay
