Right Click is not working in Incident form
udaybura
When i click Right Click in the incident form it is showing the system right click optionsimage.png
Nikhil Bajaj9
Tera Sage
Hi @udaybura ,
Either right click on the Form header- Greay strip at top or right click on any Column label to get the content menus. If you will right click on any other area (In between Form) - it will open the system menu only. This is expected behavior. If Right click on field labels are not opening the Content menu then it is an issue.
If my answer helped you, please mark it- solution accepted.
Nikhil Bajaj
