subflow - how to use reference field?
Hafila Hatta
hi. i want to pass Assignment Group into a subflow to be used in Create Catalog Task action. so i have declared input below as reference.
then i used that input to set the Assignment Group for the catalog task. however once i tested it, the assignment group is empty. any idea why? in the execution, seems like the value is there
hi. i didnt do exactly as per your suggestion as it didnt work. but it gave me an idea.
i added a lookup record action in the flow to lookup the subflow input = assignment group in table.
and reuse the value in the catalog task.
thanks for your help
@Hafila Hatta
Hope you are doing good.
@Hafila Hatta
the way I suggested should also work
Can you share what did you try ?
