Approval is not recognizing Rejected as Rejected
03-29-2024 10:03 AM
I have Ask for Approval action that is not recognizing Rejected as Rejected. If I reject approval, it is going through the workflow as it is approved during testing.
When I reject, it doesn't recognize it.
04-07-2024 12:11 AM
Hi @MelisaB,
Is Action #4 (Wait for condition), waiting for the Task from Action#3 to be closed completed?
Also, can you share the screenshot of the RITM itself including the state and approval fields?
04-08-2024 05:02 AM
Hi James,
Yes, Action #4 is waiting for the task from Action #3 to be Closed Complete. Here is the RITM screenshot:
04-08-2024 12:38 PM
Hi @MelisaB,
Nothing looks out of the ordinary, is it possible that you have more than one Flow or Workflow running on the RITM?
Also, can you check the 'state' of the approval records [sysapproval_approver] and the 'approval' field of the group approval records [sysapproval_group]?
One of these may be automatically set to 'Cancelled'
Cheers
05-15-2026 07:05 AM
were you able to figure out why the rejections were passing Cancelled to the workflow?
