Code not working in script step in flow designer whereas it is perfectly working fine in background
JerryJ071847183
Tera Sage
Hello community members,
Code not working in script step in flow designer whereas it is perfectly working fine in background.
Any idea what could be the reason?
//background script works fine gives the content present in text file.
var output = '';
var is = new GlideSysAttachment().getContentStream(sysid);
var reader = new GlideTextReader(is);
var ln = ' ';
while((ln = reader.readLine()) != null) {
// gs.info(ln);
output = ln;
gs.print(output);
// Same script not  fine in Script Step in action
var is = new GlideSysAttachment().getContentStream(inputs.AttachmentSysid);
var ln = ' ';
 // gs.info(ln);
  outputs.data = ln;
//gs.print(outputs.data);
})(inputs, outputs);
Please assist if you can let me know what needs to be changed in code in flow side
JerryJ071847183
Tera Sage
Any update can anyone assist here?
Reyes
it could be a scope issue, instead of getContentStream() can you try getContentBase64() and output the results in /sys.scripts.do in the same scope as the flow
Adam Hunley
I have the same issue and I have opened a case with support a month ago. They are still trying to figure out the issue.
