Condition Builder in Record Producer or Process Automation Designer
rvkvivekofficia
Hi All, Is there a way to create condition builder in record producer as a variable.
using process automation designer "User Form" activity we can bring the condition builder. however CHANGES;CHANGESFROM;CHANGESTO is not available in the view.
ahan
@rvkvivekofficia you can add a condition builder with extended operators check below link
Extended Operators in SN Desktop Filter widget
after doing all the configuration shown in above link you can add the widget in record producer as custom type variable..
If my answer help you please mark it as Accept As Solution.
Thanks!
