do while loop is not working in flow designe
JayS56800927307
Hello Guys,
I have used the below code in the flow designer for the print logs. but it is running only for the one times in flow designer.
var loop count=0;
var i= 0;
do {
loop_count=loop_count+1;
console.log(num);
i++;
while (i < 5);
output: 1,2,3,4,5
here loop count is integer .it is running only one time only.
i have added add operation over here one loop_count  but not getting output 1,2,3,4,5 system log. please help
2 ACCEPTED SOLUTIONS
newhand
@JayS56800927307
YES,because you writed [less than 5] at the [until] part ....
The first time you run the loop...the  [loop_count] becomes 1  ,and it  is  [less than 5]  ,so the loop is ended.
you need to change [less than 5] to [more than 5]...
Please mark my answer as correct and helpful based on Impact.
As per the image you provided earlier, your flow variable's backend name is not loop_count. See the below image which you provided.
So, in your script, use the proper backend name of your flow variable. In my case it was loop_count.
return fd_data.flow_var.<backend_name_of_your_flow_variable> + 1;
Muhammad Khan
It would be something like below.
Output
Set Flow Variables
Log
Until
JayS56800927307
thank you for your inputs . Could you please tell what you have set type of variable in the flow designer ?
newhand
@JayS56800927307
