Flow Designer: Missing Save, Test, and Activate/Deactivate Options in Developer Instance
KauêWilliam
I'm encountering an issue in my Developer Instance where the options to Save, Test, and Activate/Deactivate a flow are not appearing when i open Flow Designer. This is not happening for other members of my team, so I believe it's an issue specific to my instance.
I have tried restarting the instance and clearing the cache, but the problem persists. I would appreciate any help or guidance on how to resolve this.
Has anyone faced a similar issue or knows of a potential solution? Any advice would be greatly appreciated!
Thank you in advance.
Mike Edmonds
Take a look at this support KB article. Export the XML of the records on the mentioned tables from a working instance and you should be good to go.
https://support.servicenow.com/kb?id=kb_article_view&sysparm_article=KB1198587
