Flow designer vs Scheduled Job
rajeeshraj
What best-practice guidelines should be used to decide between Flow Designer and a scheduled job—such as transaction volume, payload size, event queue impact, or similar factors?
9 REPLIES 9
Aditya_hublikar
Hello @rajeeshraj ,
 Choice between Flow Designer and a Scheduled Job mainly depends on performance, volume, and use case. Flow Designer is best for event-driven processes like record updates, approvals, and integrations where readability and easy maintenance are important, and the data volume is low to moderate. However, for high-volume or performance-intensive tasks—such as processing thousands of records, handling large payloads, or running background batch jobs—a Scheduled Job is a better option because it runs more efficiently without adding load to the flow engine or event queue. In real projects, we often use a hybrid approach, where Flow Designer handles the trigger and orchestration, while heavy processing is done using scripts for better performance and scalability.
If this helps you then mark it as helpful and accept as solution.
Aditya
Hello @rajeeshraj ,
I hope you are doing well . Does your query is resolved ?
If community responses helps you then mark it as solution ,  so this will help other future queries .
Aditya
vaishali231
hey @rajeeshraj
Choosing between Flow Designer and a Scheduled Job (Scripted Scheduled Job) should be based on use case complexity, execution frequency, data volume, and performance impact. Below are practical, experience-based guidelines to help you decide.
When to Use Flow Designer
Use Flow Designer when the requirement is event-driven, maintainable, and low-to-moderate volume.
Best-fit scenarios:
  • Triggered by record changes (insert/update/delete)
  • Requires low-code / no-code maintainability
  • Involves approvals, notifications, or integrations
  • Business users or admins may need to modify logic later
Guidelines:
  • Keep transaction volume low to medium (avoid thousands of executions per minute)
  • Payload size should be small to moderate (large data processing can slow flows)
  • Avoid long-running loops or heavy data transformations
  • Be mindful of Flow Engine execution limits and licensing (if applicable)
  • Prefer subflows and actions for reusability and clarity
Why:
Flow Designer runs on the Flow Engine, which adds abstraction and overhead. It is optimized for readability and orchestration, not heavy processing.
When to Use Scheduled Job (Scripted)
Use a Scheduled Job when the requirement is bulk processing, performance-critical, or backend-heavy logic.
Best-fit scenarios:
  • Batch processing (e.g., updating thousands of records)
  • Periodic jobs (hourly, daily cleanup, sync tasks)
  • Complex logic requiring optimized GlideRecord queries
  • Data transformation or large payload handling
Guidelines:
  • Suitable for high transaction volume
  • Efficient for large payloads and bulk updates
  • Avoid triggering excessive events or workflows inside loops
  • Use setWorkflow(false) and autoSysFields(false) where appropriate
  • Optimize queries with indexed fields
  • Consider chunking/batching to avoid long-running transactions
Why:
Scheduled Jobs run as server-side scripts, giving you full control and better performance for heavy operations without Flow Engine overhead.
Key Decision Factors
Factor
Flow Designer
Scheduled Job
Trigger Type
Event-driven
Time-based
Volume
Low–Medium
Medium–High
Payload Size
Small–Moderate
Large
Performance
Moderate
High
Maintainability
High (low-code)
Medium (requires scripting)
Execution Overhead
Higher (Flow Engine)
Lower
Practical Recommendation
  • If your use case is “when something happens - do something” - go with Flow Designer
  • If your use case is “process large data regularly or in bulk” - go with Scheduled Job
    For hybrid scenarios:
    • Use Scheduled Job for bulk processing
    • Trigger Flow Designer selectively for business logic (only where needed)
Common Pitfall to Avoid
  • Using Flow Designer for mass updates (e.g., 10k+ records) - leads to performance issues and event queue load
  • Using Scheduled Jobs for simple event-driven logic - reduces maintainability unnecessarily
If this response helps, please mark it as Accept as Solution and Helpful.
Doing so helps others in the community and encourages me to keep contributing.
Vaishali Singh
hey @rajeeshraj
Hope you are doing well.
Did my previous reply answer your question?
If it was helpful, please mark it as correct ✓ and close the thread . This will help other readers find the solution more easily.
Vaishali Singh
shibasou
Hello.
This is a perspective that others haven't mentioned.
It's because there's a difference when migrating functionality to other environments.
Flow Designer can be migrated using update sets, whereas scheduled jobs cannot be migrated using update sets and require migration via XML, etc.
Mark Helpful if you accept the solution.
Thank you.
