Is it possible to add approvers to a workflow using flow designer ?
JoseSantosA
I have installed a plugin, this plugin has a catalog item which uses a workflow, I wanna know if it's possible to add or remove approvers based on certain conditions without having to modify the OOB workflow. The reason of why i dont want to modify the existing workflow is to avoid lossing my changes in a future update release for the plugin.
LarryP888183452
Greetings @JoseSantosA. I would recommend looking to creating and utilizing a Decision Table which is another Flow Designer solution. It gives you the option to create as many options/scenarios as you need. I will include a link to some ServiceNow documentation below. I hope this information is helpful!
Decision Tables
