setValue in select box in catalog client script
Hafsa1
I have 2 region field with value as "NA" for "North America.
I am using catalog client script to fix value of first region into another and second one is read-only
But it is not updating. What wrong I'm doing?
var regions = g_form.getValue("u_region").toString();
I used g_form.setValue("u_region_1", regions );
Rajesh Chopade1
hi @Hafsa1
In your script, you're checking for nature=="3",  but the variable nature is not defined in the code you shared. Ensure that nature is properly set and that it holds the expected value before the condition.
f u_region_1 is read-only, g_form.setValue might not be able to update it.
Here's the revised script with these fixes:
var nature = g_form.getValue('nature'); // Get the 'nature' field value
if (nature == "3") {
    var regions = g_form.getValue("u_region");
    alert("Region is: " + regions);
    g_form.setValue("u_region_1", regions);  // Set the value of u_region_1 to u_region's value
    console.log("Value of u_region_1 after set: " + g_form.getValue("u_region_1")); // Debugging
    // If u_region_1 is read-only, make it editable for a moment
    g_form.setReadOnly('u_region_1', false); // Make editable
    g_form.setReadOnly('u_region_1', true); // Make it read-only again
I hope my answer helps you to resolve your issue, if yes please mark my answer helpful and correct.
thank you
Rajesh
