Start the Adobe Sing flow from Flow Designer or another method
albert85
Hello friends.
I have a requirement to automatically start the Adobe Sing flow when a task is generated, also passing the signing users and an attachment. I think that from Flow Designer or another method it could be achieved.
Could any of you guide me on how to carry out this requirement?
Thanks in advance, regards
Tai Vu
Hi @albert85
You can define a business rule, which will trigger when a record is generated. And let's use the below API to start the flow.
startFlow(String name, Map inputs)
Sample.
var inputs = {};
inputs['current'] = now_GR; // GlideRecord of table: Incident
inputs['table_name'] = 'incident';
var contextId = sn_fd.FlowAPI.startFlow('global.test_flow', inputs);
Cheers,
Tai Vu
