workspace notification sound
prithatcs
hello,
earlier when the agents used to work on a different application or browser tab, when a new chat came, there used to be a audio notification.
however, we no longer get the sound notification.
but the following chats give a sound notification if the window is minimized.
i want to know where the sound notification for virtual agent is configured.
2 ACCEPTED SOLUTIONS
Dennis Ford
First, go to Advanced Work Assignment>Settings>Service Channel.  Select "Chat" or whatever your Service Channel name is and check the Inbox Alert Audio to see that there is a sound file configured.
Secondly,  in the Agent Workspace Inbox, the agent should click the gear icon
on the left to make sure their audio alerts are enabled.
Hi @prithatcs
In addition to what @Dennis Ford has mentioned can you also check this KB here - KB0995140.
The workaround mentions some script as attachment to the KB. However no files are attached.
Please replicate the issue based on the steps mentioned.
If the steps are the same, then your instance would be affected by this defect.
Also, I would recommend you to check with the Hi support team on KB0995212 which is mentioned but the KB cannot be accessed.
11 REPLIES 11
Hello, do you know how to get to these? I don't see this menu.
Hi Kaylee,
In the Navigator, type in Social IT. Under Chat Administration you will see Properties. Click on it to open the menu. You can verify if the files loaded have actual info in them or load new ones as you deem necessary.
Hope this helps.
Marshall
unfortunatley i dont have that option. do you have the exact UI page i can try instead?
The sound files are stored in a system property. If you do not have admin role you will not be able to see these files.
I am the admin, but was looking for if there was the oob properties page shown above for chat. I am able to find the mp3 property in sys_properties.
