work notes from problem_task to problem is not working at all.
tghadage124
hi all ,
var problemRec = new GlideRecord('problem');
problemRec.addQuery('sys_id', current.problem);
problemRec.query();
if(problemRec.next()) {
        problemRec.work_notes = current.work_notes.getJournalEntry(1);
problemRec.update();
this is the code for the same.
whenever i am tying infrom problem_task to problem record its it going like this in loop
please look into it. once if you have answer do let me know.
Rajesh Chopade1
hi @tghadage124
Looks code is potentially causing a loop between the 'problem_task'  and problem records. This could be happening because you're modifying the problem record's work notes in response to a change in the problem_task record, and that update might trigger an event that starts the process over again.
Could you try following code once :
problemRec.query();
if (problemRec.next()) {
    // Check if the work notes have already been updated to avoid recursion
    if (!problemRec.u_processed) {
        // Add the journal entry to work notes
        // Set a flag to avoid recursion
        problemRec.u_processed = true;
        // Update the problem record
I hope my answer helps you to resolve your issue, if yes please mark my answer helpful and correct.
thank you
Rajesh
Brad Bowman
Mega Patron
Do you have Filter Conditions on the Business Rule when Work notes changes?  Do you have any Business Rules running on the problem table that is doing anything with work_notes?
-O-
Is there maybe a business rule that does the reverse: when the work notes on the problem are added, it copies those to all problem tasks?
shivatmika_19
Hi @tghadage124,
You can try the below code
BR: After update
Condition: work notes changes
table: problem_task
Script:
// Add your code here
problemRec.query();
var workNotes = current.work_notes.getJournalEntry(1);
if(workNotes.indexOf(current.number+': ') == -1){
problemRec.work_notes = current.number+': '+workNotes;
else{
gs.addInfoMessage('No associated problem record exists for the problem task');
})(current, previous);
Note: you can modify the string for stopping the loop (i used [record number : ---> e.g., PTASK1234 🙂
